I picked up some 39mm PWK's for the right price, does anybody know a good starting point at? I'm in the Wichita, KS area. I did that elevation finder for little sahara in Waynoka, and it was 473 meters above see level unless I did it wrong...LOL. Any input is appreciated. Mods are listed below. Thanks!
Shearers In Frame's (Small Bore)
421 Cub w/ 17cc Domes
Cut stock cages with Boysen carbon fiber petals
32:1 Oil/Fuel Ratio
K&N Pod Filters
is there any porting on the cylinders? 50 pilots and 180 mains and work your way down
No, not yet. Maybe after my wedding. They came with 160's and 170's. Stick the needle in center? By the way, the manifolds I got with these things don't have the ports for the balancing tube. What's this gonna affect? Thanks for the jetting tips.
Will not effect anything ditch it.
what needle dek, cel?
48-52 pilot
main 150-160
needle in center
live an hour east of you
ran 45 pilot dgh mid clip and 160 mains in the summer 165 in the winter.
pretty same setup.
You buy the needles from Sudco? Also, where you put the air/fuel screw from bottom? The guy I got these from had the screw cracked half a turn out, 55 pilots, 160 mains, odk (could be wrong, I've slept since then) with the needle all the way down. Lol. I see why he didn't like the carbs. I don't think he had a clue as to what he was doing.
