BANSH-alena-jol-EE Posted May 15, 2009 Report Posted May 15, 2009 hello, i got sst pipes, pods, vf3, so far i have gotten bigger main jets and pilots but havent moved or changed the needle any... bike is running well but i would like to move the needle so its running richer, just incase shes lean? this sound right? wouldnt she be running lean on a stock needle with those mods? thanks oh yah and which way do i move the needle to make her richer or leaner? thanks again! Quote
06specialedition Posted May 16, 2009 Report Posted May 16, 2009 Moving the clip up is lean....down is rich. Quote
dragbanshee Posted May 16, 2009 Report Posted May 16, 2009 hello, i got sst pipes, pods, vf3, so far i have gotten bigger main jets and pilots but havent moved or changed the needle any... bike is running well but i would like to move the needle so its running richer, just incase shes lean? this sound right? wouldnt she be running lean on a stock needle with those mods? thanks oh yah and which way do i move the needle to make her richer or leaner? thanks again! It doesn't mean its going to be lean, but you can play with it, one notch up or down from center which ever runs best. I would try to stay in that range, unless you needed to go richer. Lowest notch from the blunt end is richest. Quote
