mrbigsacks Posted May 15, 2009 Report Posted May 15, 2009 I do mostly trail riding. what should I use for a sprocket for mo bottom end? Quote
4strokekilla5 Posted May 15, 2009 Report Posted May 15, 2009 I do mostly trail riding. what should I use for a sprocket for mo bottom end? 13tooth front sprocket is what you want Quote
mrbigsacks Posted May 15, 2009 Author Report Posted May 15, 2009 13tooth front sprocket is what you want Leave the back the same? Quote
mrbigsacks Posted May 15, 2009 Author Report Posted May 15, 2009 Leave the back the same? thanks. what did the 43 do as far as response? Quote
4strokekilla5 Posted May 15, 2009 Report Posted May 15, 2009 Leave the back the same? yeah you will gain acceleration and bottom end with that smaller sprocket Quote
mrbigsacks Posted May 15, 2009 Author Report Posted May 15, 2009 yeah you will gain acceleration and bottom end with that smaller sprocket thanks for the info I will give it a shot Quote
4strokekilla5 Posted May 15, 2009 Report Posted May 15, 2009 thanks for the info I will give it a shot no problem, hope u like the change Quote
Sammy Posted May 15, 2009 Report Posted May 15, 2009 I'm 14/44, but I ride a lot of tight technical trails. So the lower gearing helps a ton. But 5-6 gear are still long enough for some good speed on the faster trails. Quote
GrMeyer Posted May 15, 2009 Report Posted May 15, 2009 just drop a T up front and off you go. its better for when you get into the tree's you will lose some top end but how often are you pinned in 6th? Quote
