I always check compression before I fire it up and again after it's broken in. I haven't noticed much difference in the readings actually, but I never checked it warm.
You need to check squish before you run it. You wont get an accurate compression reading until its been ran and checked warm.
I'll check the squish,Thanks
I think I'll do a test then break her in and see the diff.
i check my before i fire it so you know what kind of fuel to run. race gas or pump gas
I'm not changing my setup so I'll still be running pump. 21cc domes.
