shee4speed Posted May 13, 2009 Report Posted May 13, 2009 just putting my new topend together and wondering if its worth while to do a compression test before running her. Quote
Snopczynski Posted May 13, 2009 Report Posted May 13, 2009 You need to check squish before you run it. You wont get an accurate compression reading until its been ran and checked warm. Quote
J-Madd Posted May 13, 2009 Report Posted May 13, 2009 I always check compression before I fire it up and again after it's broken in. I haven't noticed much difference in the readings actually, but I never checked it warm. Quote
tundish2800 Posted May 13, 2009 Report Posted May 13, 2009 i check my before i fire it so you know what kind of fuel to run. race gas or pump gas Quote
shee4speed Posted May 13, 2009 Author Report Posted May 13, 2009 You need to check squish before you run it. You wont get an accurate compression reading until its been ran and checked warm. I'll check the squish,Thanks I always check compression before I fire it up and again after it's broken in. I haven't noticed much difference in the readings actually, but I never checked it warm. I think I'll do a test then break her in and see the diff. i check my before i fire it so you know what kind of fuel to run. race gas or pump gas I'm not changing my setup so I'll still be running pump. 21cc domes. Quote
