bigcountry61 Posted May 12, 2009 Report Posted May 12, 2009 first off I am new here, been reading for quite a bit but decided to just post and see if I can get some direct feedback. I ride trails and will drag a lil on street. 1. I am going do redo the front suspension. Should I do the yzf450 conversion or something else? I weigh about 300lbs 2. I am going to redo the brakes, any specific upgrades I should research? 3. I am going to do a 5mm crank, where is the cheapest spot to pick up one at online?? will also need a good deal on piston 4. looking to get some black CPI small bore inframes, best place to buy online ? 5. pro-taper SE will work fine with stock setup ? 6. cheapest place to buy fullbores? sorry for all the questions, just want to do it right... Quote
GrMeyer Posted May 12, 2009 Report Posted May 12, 2009 first off I am new here, been reading for quite a bit but decided to just post and see if I can get some direct feedback. I ride trails and will drag a lil on street. 1. I am going do redo the front suspension. Should I do the yzf450 conversion or something else? I weigh about 300lbs if your wanting to upgrade the breaks then do the full front yfz swap. just get the spacers machined. 2. I am going to redo the brakes, any specific upgrades I should research? 3. I am going to do a 5mm crank, where is the cheapest spot to pick up one at online?? will also need a good deal on piston 4. looking to get some black CPI small bore inframes, best place to buy online ? try the forsale section 5. pro-taper SE will work fine with stock setup ? 6. cheapest place to buy fullbores? sorry for all the questions, just want to do it right... Thats about all I can fill out for you...Other then Ebay!!! I have found most of my stuff off there and have had great luck...and try craigslist.org Quote
