4strokekilla5 Posted May 11, 2009 Report Posted May 11, 2009 How long and complicating is it to do? Quote
SAVAGE420 Posted May 11, 2009 Report Posted May 11, 2009 1/2-1hr from clutch cover off to clutch cover on. Quote
4strokekilla5 Posted May 11, 2009 Author Report Posted May 11, 2009 1/2-1hr from clutch cover off to clutch cover on. Ok thanks, lol do u have a tips for removing stubborn ass clutch cover screws that are stripped Quote
DallasGDub Posted May 11, 2009 Report Posted May 11, 2009 1-10 (10=hardest), I give it a 4 if you do not use tools that much, and a 1 if your a gear head. So it is pretty easy either way. Quote
2003LimitedBanshee Posted May 11, 2009 Report Posted May 11, 2009 Do not forget to soak the fibers over night before though! I actually have never not soaked them, just always been told and heard to, so... If you don't and then figure out you need to, it's more like a day plus... Quote
SAVAGE420 Posted May 11, 2009 Report Posted May 11, 2009 Ok thanks, lol do u have a tips for removing stubborn ass clutch cover screws that are stripped Soak them with penetrating fluid and let soak for a lil while. If you have a dremel and/or an air die grinder, put a small cut off wheel on there and cut a nice slot in the top of them and use a BIG slotted screw driver to turn them out. But give them a couple good hits on top of the screw driver before trying to turn them out to loosen them up. If that don't work for you, get a pointed punch and hammer and hit the right side of the slot you made on the top of the bolts with the hammer and punch and they WILL break free and start to turn. And if all that don't work, but it will, get a torch and put some heat into the bolts (not to much to burn your house down though ) and they will come out right away. Only thing though, you will have to get new bolts if the slots get fuct up or stripped more.. Can get new bolts at the hardware store or even better, get the allen head bolts for the clutch cover for like $5 at RMATV, never strip them again. Good luck Quote
4strokekilla5 Posted May 11, 2009 Author Report Posted May 11, 2009 Soak them with penetrating fluid and let soak for a lil while. If you have a dremel and/or an air die grinder, put a small cut off wheel on there and cut a nice slot in the top of them and use a BIG slotted screw driver to turn them out. But give them a couple good hits on top of the screw driver before trying to turn them out to loosen them up. If that don't work for you, get a pointed punch and hammer and hit the right side of the slot you made on the top of the bolts with the hammer and punch and they WILL break free and start to turn. And if all that don't work, but it will, get a torch and put some heat into the bolts (not to much to burn your house down though ) and they will come out right away. Only thing though, you will have to get new bolts if the slots get fuct up or stripped more.. Can get new bolts at the hardware store or even better, get the allen head bolts for the clutch cover for like $5 at RMATV, never strip them again. Good luck thank you soo much im going threw your steps right now lol Quote
justind574 Posted May 11, 2009 Report Posted May 11, 2009 I just went through this if you cant get the screws out crank down a set of vise grips on the head and they will turn easy. While I was at it I bought the allen head bolts to replace them. Quote
4strokekilla5 Posted May 12, 2009 Author Report Posted May 12, 2009 I just went through this if you cant get the screws out crank down a set of vise grips on the head and they will turn easy. While I was at it I bought the allen head bolts to replace them. i tryed it no luck :/ they just dont want to come off. i plan on buying one of those bits to remove striped bolts tommaro Quote
SAVAGE420 Posted May 12, 2009 Report Posted May 12, 2009 i tryed it no luck :/ they just dont want to come off. i plan on buying one of those bits to remove striped bolts tommaro Do what i said and they WILL come out. There not in there very tight man, hammer and punch in the slot at and ANGLE with some heat just before and they will turn man. Get out there and do it. :thumbsup: Quote
Paul M Posted May 12, 2009 Report Posted May 12, 2009 (edited) Impact drivers work great ! couple whacks with a hammer they back right out! Edited May 12, 2009 by Paul M Quote
4strokekilla5 Posted May 12, 2009 Author Report Posted May 12, 2009 Do what i said and they WILL come out. There not in there very tight man, hammer and punch in the slot at and ANGLE with some heat just before and they will turn man. Get out there and do it. :thumbsup: yeah ill give it another shot tommaro, i have to much homework and dont have the time now lol highschool sucks. Quote
bassmaster345 Posted May 12, 2009 Report Posted May 12, 2009 Used vise grips on mine to loosen then turned them out rest of the way with the screwdriver. Quote
justind574 Posted May 12, 2009 Report Posted May 12, 2009 I wouldnt waste money on the screw extractors I did and they didn't do a thing. vise grips or what savage said. Quote
