ive bought a new top end off a member and am in need of some help to determine what domes and timing i will be able to run with my available fuel of 98 octane and being between sea level and 300 feet.
engine is:
4mill
k&T mid range dune ported 66.25mm bore with blaster pistons
33pwks
t5s
also, with this setup what rough power can i expect?
do you know your exhaust port height? it's more about a safe compression ratio. mabey the birthday boy will chime in with the right ratio off the top of his head. if you do a search, i believe someone had a link to the calculator
