Hi i put my 34pjs on my bike the past winter i had it running great. Since it is starting to get warmer i think its running a little to rich now. I am running 45 piolt and 158main. I would like to know where to start when i am trying to lean it out do i change the piolt or main and how much. Any help would be appriated THANX Will
that depends on the temp and humidity change. going from below freezing to about 60f, is 1-2 sizes leaner on the main, and 1 size on the pilot, but if it's alot more humid, like durring breakup, it will want to be almost 1 size leaner, which will make you too lean when it dries out. start with a plug chop on the main, 1 size down, and then see if it needs a smaller pilot.
Go two sizes down on the main, turn the air screw out 1/2 turn...
Obviously, your mileage will vary, but I've rarely had to change a pilot jet from winter to warm weather, the air screw handled it.
Thanks i will try it this weekend if the weather is ok
  • 1 year later...
that depends on the temp <u>and</u> humidity change. going from below freezing to about 60f, is 1-2 sizes leaner on the main, and 1 size on the pilot, but if it's alot more humid, like durring breakup, it will want to be almost 1 size leaner, which will make you too lean when it dries out. start with a plug chop on the main, 1 size down, and then see if it needs a smaller pilot.
I'm new to Banshee HQ, and you seem like you have a wealth of knowledge on these bikes. What size jets would you start with in a 2004 Banshee with stock OEM carbs, PT mids, Ready Filter with OE air box with lid ON, adjustable timing plate, and a Trinity's stage IV Cool Head/21cc domes? My elevation is 700 ft above sea level. I don't know if this matters but the motor has also been punched .020. Please contact me back as soon as possible.
i would think you would be around oh about 310 on the main but i i would also mess with the needle positioning as well. but i think i should be pretty close with the jets oh and maybe up one on the pilot maybe not. pilot is for idle and up to 1/4 throttle
