decon Posted May 3, 2009 Report Posted May 3, 2009 I put the TORS removal kit on my carbs with the idle kit, my bike still idles real low and cuts off. I have the idle screws turned all the way in. What could be the problem. Quote
Rodneya Posted May 3, 2009 Report Posted May 3, 2009 Did you grind a the piece of the carb that the idle screw goes into. If you don't, the screw wont go in far enough. Quote
pabansheematt Posted May 3, 2009 Report Posted May 3, 2009 Did you grind a the piece of the carb that the idle screw goes into. If you don't, the screw wont go in far enough. X2. The side of the carb is tapered. You got to gring it flat. I'd take a 1/4" off. that should fix your problem. Dont forget to sync them. Quote
