Hey guys I searched around a little before posting this. This is what I have:
4mill stroker
Cub Cylinder with no porting (only stock porting as this is a "trail" bike) (literally straight off the shelf)
35 PWK Airstrikers with power jet installed (Running on Race Gasoline (turbo blue))
K&N POD Filters
CPI Inframes
lockout clutch (don't think that matters).
I'm in Michigan so the elevation is 700' above sea level.
80% of the time will be trail riding and going through the gears, so the low/mid range of the jetting is very important. I'd even sacrifice power for a safety cushion.
I go to the silver dunes a couple times during the summer, where it will be WIDE OPEN THROTTLE racing.
Can anyone give me something to start with????
This is what i started with:
DG? needle in middle (wouldn't idle), Would only idle with both chokes on.
raised it one notch and it idled.
the main jet is 150 ish... One higher than a 145 whatever that is.
the pilot is a 45 I believe.
With this setup it would idle (unless chokes were on) and there was no low range at revving.
Thank you for your input. I really appreciate this.
