BillyRay Posted April 15, 2009 Report Posted April 15, 2009 I have yet to use the paddles that came with my bike but I intend to use them in the next few weeks. Here in Minnesota we have no dunes so I have been running only dirt tires. I have a set of 20x10-8 8 paddle haulers and I was wondering what air pressure everyone is running in this type tire? Thanks in advance for the advice. Quote
DopeyTripod Posted April 15, 2009 Report Posted April 15, 2009 it depends on the terain, your wheight, HP, Ect. just put 4lbs and go from there. Quote
sandnut Posted April 15, 2009 Report Posted April 15, 2009 Like he said it depends on everything, you can go from 1 to 6 psi. Quote
sheefreak Posted April 15, 2009 Report Posted April 15, 2009 As mentioned above, w/an 8 inch rim, you have lots of room for adjustment. I would also start at 4 and go from there. Quote
GrMeyer Posted April 16, 2009 Report Posted April 16, 2009 I start with 5psi and see how they hook up and go down from there. if it is really soft sand ill drop them down to around 4psi and if it is wet sand ill put them up to around 5-6 depending on how much grab im getting out of the tires but all in all 5 psi is a good starting point. Just remember that the temp in the tires will change from day to night so the psi will go up and down. Quote
