mrbigsacks Posted April 6, 2009 Report Posted April 6, 2009 I have a 99 banshee with TORS plugged in backfires runs like crap. Unplug TORS runs good won't hold idle unless you choke carb manually other side runs fine. out of ideas. anyone Quote
Ineedmoney Posted April 6, 2009 Report Posted April 6, 2009 Have you 1. cleaned out the carbs 2. jetted it properly. 3. checked compression 4. maybe needs top end rebuild 5. mihgt need new tires, 6. maybe its pissed at you because u dont know how to ride it. 7. I will give you 100 $ for it 8. Are u using premium gas. 93 octane to be exact 9. 32-1 would do nicely for stock engines 10. make sure its getting gas. Quote
mrbigsacks Posted April 6, 2009 Author Report Posted April 6, 2009 Have you 1. cleaned out the carbs 2. jetted it properly. 3. checked compression 4. maybe needs top end rebuild 5. mihgt need new tires, 6. maybe its pissed at you because u dont know how to ride it. 7. I will give you 100 $ for it 8. Are u using premium gas. 93 octane to be exact 9. 32-1 would do nicely for stock engines 10. make sure its getting gas. all the above you wish $100 could do without smart ass remarks. thanks for wasting my time Quote
Ineedmoney Posted April 6, 2009 Report Posted April 6, 2009 So u have done all fo the above. or r u jsut mad cuz of my smart ass remarks. Quote
blowit Posted April 6, 2009 Report Posted April 6, 2009 I have a 99 banshee with TORS plugged in backfires runs like crap. Unplug TORS runs good won't hold idle unless you choke carb manually other side runs fine. out of ideas. anyone TORS is doing it's job. You have a bad throttle cable or need to sync your carb slides. Again, the TORS is working. Probably cutting ignition when you chop throttle and when you get back in it, it pops as it picks back up. Either way, I feel confident in my diagnosis. Brandon Quote
mrbigsacks Posted April 6, 2009 Author Report Posted April 6, 2009 So u have done all fo the above. or r u jsut mad cuz of my smart ass remarks. Pissed because i'm stumped and nobody has any ideas top end rebuilt carbs rebuild new stator new plate new flywheel new cdi. kicks over runs good just won't hold idle. give me a little credit I do have mechanical knowledge. any help would be great Quote
blowit Posted April 6, 2009 Report Posted April 6, 2009 Just replied with your answer. 15yrs of ATV repairing. trust me :thumbsup: B Quote
mrbigsacks Posted April 6, 2009 Author Report Posted April 6, 2009 (edited) Just replied with your answer. 15yrs of ATV repairing. trust me :thumbsup: I have sync the carbs but you think it's throttle cable? I'll give it a try one on the way should have it tomorrow. thanks for the heip if it works you are the man. keep you posted. should i leave TORS unpluged or plugged in B Edited April 6, 2009 by mrbigsacks Quote
blowit Posted April 6, 2009 Report Posted April 6, 2009 (edited) You should certainly be able to find a bad cable before replacing it. Remember also that there is cabling inside the TORS boxes. If they are sticking and not letting the slides come down right, that is a problem. There are contacts inside the TORS. You should be able to remove the main throttle cable and inspect for fraying and such. If there is a problem, it could be found in 5min. If you only have one side idling, there is an issue there. I am going off your statements mind you. If you have a plugged jet, it will act similar but as soon as you said there was an improvement when unplugging the TORS, I went to throttle cables and slide balance. The way the TORS works is there is a switch in the thumb throttle that indicates you are off throttle. If the slides do not hit their switches at the same time to indicated they are "off" too, this will enable a ground loop to cut the ignition. ie, sticky cable, bad cable, carb sync, ALL get put on the "junk TORS" bandwagon . It was a good idea, just needed more refinements. B Edited April 6, 2009 by blowit Quote
mrbigsacks Posted April 6, 2009 Author Report Posted April 6, 2009 (edited) You should certainly be able to find a bad cable before replacing it. Remember also that there is cabling inside the TORS boxes. If they are sticking and not letting the slides come down right, that is a problem. There are contacts inside the TORS. You should be able to remove the main throttle cable and inspect for fraying and such. If there is a problem, it could be found in 5min. If you only have one side idling, there is an issue there. I am going off your statements mind you. If you have a plugged jet, it will act similar but as soon as you said there was an improvement when unplugging the TORS, I went to throttle cables and slide balance. The way the TORS works is there is a switch in the thumb throttle that indicates you are off throttle. If the slides do not hit their switches at the same time to indicated they are "off" too, this will enable a ground loop to cut the ignition. ie, sticky cable, bad cable, carb sync, ALL get put on the "junk TORS" bandwagon . It was a good idea, just needed more refinements. B ok thanks for your help. gives me something to go off. but I checked the sync and it looks on if not very close. whats the setting for idle screws on TORS? do all stock carbs have choke hose between carbs? Edited April 6, 2009 by mrbigsacks Quote
BansheeDan Posted April 6, 2009 Report Posted April 6, 2009 I will almost be willing to put money on it that as stated above the slides are out of sync. My bike was doing the exact same thing the first time I started it. Got the slides right and it idles great...even with my 34mm keihin's. As far as the tors goes....just leave it unhooked,its more of a pain in the ass then its worth. As also stated above go through your tors boxes on the tops of the carbs,make sure there are no freyed cables,sticking etc... You can get the carbs sync'd pretty close by eye use the adjustment knobs on the tors boxes to adjust them,but Jeff at F.A.S.T. Racing has a nifty lil tool that makes the job super easy if ya got the $50.00 for it. Dan Quote
mrbigsacks Posted April 6, 2009 Author Report Posted April 6, 2009 I will almost be willing to put money on it that as stated above the slides are out of sync. My bike was doing the exact same thing the first time I started it. Got the slides right and it idles great...even with my 34mm keihin's. As far as the tors goes....just leave it unhooked,its more of a pain in the ass then its worth. As also stated above go through your tors boxes on the tops of the carbs,make sure there are no freyed cables,sticking etc... You can get the carbs sync'd pretty close by eye use the adjustment knobs on the tors boxes to adjust them,but Jeff at F.A.S.T. Racing has a nifty lil tool that makes the job super easy if ya got the $50.00 for it. Dan but if I leave it unplugeed dosen't hold idle Quote
BansheeDan Posted April 6, 2009 Report Posted April 6, 2009 ok thanks for your help. gives me something to go off. but I checked the sync and it looks on if not very close. whats the setting for idle screws on TORS? do all stock carbs have choke hose between carbs? Yes..all stock carbs have the choke tube,they wont run right with out it. The knobs on the tors is the idle/slide adjustment. Dan Quote
blowit Posted April 6, 2009 Report Posted April 6, 2009 ok thanks for your help. gives me something to go off. but I checked the sync and it looks on if not very close. whats the setting for idle screws on TORS? do all stock carbs have choke hose between carbs? Yes, choke hose between carbs is OE. Setting idle can be done several ways but we generally back both screws out until slides are bottomed out and adjust from there by mic'ing the slides. One thing you have to watch is just because they are ok at idle, does not mean anything at half throttle. This is why vacuum testing is important for good tuning. You should also hear the slides tap down at the same time when you chop throttle. B Quote
mrbigsacks Posted April 6, 2009 Author Report Posted April 6, 2009 Yes..all stock carbs have the choke tube,they wont run right with out it. The knobs on the tors is the idle/slide adjustment. Dan so back them out all the way and go from there? looks like no were to put hose. it won't idle without TORS but throttle response is ok little hesitence Quote
