Dyno Tidbit
We ran my cousins bike on the dyno today. When we drag race his bike pulls about dead even with mine. When I have ridden it, it has alot more low end grunt than my bike. Its also a 4 mill stroker with the exhaust ports dropped down lower than stock, and a 2 into 1 intake with a 36mm lectron carb. He also has pro circuits pipes on it. It made about 6 less hp than mine on the dyno, the torque was about 3-4 ft lbs better than my motor, and he runs about 190 psi compression in it.
Just goes to show ya, torque and that low end grunt can take you a long ways. He stops making power at around 8,000rpm, my bike stops at around 8,700-8,800 rpm.
Nice info man.
That engine dyno is the shizz.
I have:
pro circuit pipes with ceramic coating
coolhead with 18cc domes 185 psi compression.
Dynoport port job
Stock cages with carbon tech mid reeds
28mm mikuni tm's with pods
Lightened flywheel
Dyna cdi with +4 degrees of timing on curve 3 and dyna coil
cascade clutch and pancake bearing
13/46 gearing
21-12-8 10 paddle super lights
wiseco pistons and .042" squish
stock stator and plate with dc conversion and a battery
works front shocks (dual rate, no resevoirs)
+6 Podos Racing swingarm with round house carrier
vbars
twist throttle
easy pull clutch perch
vision x solstice led lights
shaved plastics
cascade shifter
sand gear dual rib steer tires
home made dual pegs
tm designworks pipe hangers
cascade chain slide
tm designworks chain rollers
oury grips
underbody leds
led tail light
maxima 85 endurance trans oil
castor 927 on 110 octane at 16oz to a 5 gallon can
stainless rear brake line
and a partridge in a pear tree. :biggrin:
Dynomite crank dyno with dynomax 2000 software. All custom made engine adapters, stand, and flywheel adapter of a 1990 JS 500 driveline and engine coupler.
Theres about $13,000.00 in equipment there.
I think dual 28mm carbs on that motor would free up his top end to about 5hp more, he would probably lose about 2-3 ft lbs of torque going to the duals on his low end around 5500-6000 rpm. Lectrons make about 15-20% more low end power than any other carb, so its a good carb to run on a 2 into 1 intake.
