Been googling and reading through here but not finding a lot. Seems everything is chrome. Found some T5's and Shearers but wondering who else may be making them in the raw steel. New or used, as when I am ready for some I will look used first so if they are not in production that's ok.
im sure you can get any mfg. to make you a set in raw steel if your buying new...
as far as used, i dono if you could just strip the chrome off of a pipe..
All pipes come raw. Even the stupendous out of frame drag pipes. Usually the customer is the one who will chrome or powder coat them. Sometimes the manufacturers have a deal through someone local to them to get pipes chromed on the cheap. That way they make more money from you.
If you find a good set of pipes on the cheap. Just get them sand blasted.
