my buddy has a 96 banshee and the left cylinder has spark and compression but its running cold like its not firing and is starting to leak oil heaily out of the head it looks to be tranny oil what could be causing this problem any help would be well appreciated im thinking its a crank seal thanks plz help
If its a left side crank seal it wont burm tranny fluid,it will suck air tho,can you do a pressure test on the motor,If you look in the beginning of this section someone pinned up how to do so,You can make a tester cheap,.Check the reeds for cracks!
