sredish Posted March 26, 2009 Report Posted March 26, 2009 Can someone give me the torque specs for the cylinder and head bolts? No longer have a manual. Quote
spurdy Posted March 26, 2009 Report Posted March 26, 2009 Can someone give me the torque specs for the cylinder and head bolts? No longer have a manual. I believe it was 20 ft lbs. Just changed domes last week. Boy my memory sucks as I get older! SP Quote
scotts96fast Posted March 26, 2009 Report Posted March 26, 2009 yes 20 for both....Check out the online Service Manual,that's been pinned. Quote
spurdy Posted March 26, 2009 Report Posted March 26, 2009 yes 20 for both....Check out the online Service Manual,that's been pinned. Everytime I try to view that online manual I get an error. It just doesn't work for me. SP Quote
scotts96fast Posted March 27, 2009 Report Posted March 27, 2009 Everytime I try to view that online manual I get an error. It just doesn't work for me. SP just tried to view it and no luck....i have it on my pc and no problems. Quote
dajogejr Posted March 27, 2009 Report Posted March 27, 2009 20 ft lbs scotty. I normally torque them 10 first, then 15, 20...and then 22. If you have an aftermarket head you're working on and need a stock head torque sequence, I'll get you a pic. bascially, Criss cross the middle 4 studs, then star pattern and work your way out. Quote
sredish Posted March 27, 2009 Author Report Posted March 27, 2009 20 ft lbs scotty. I normally torque them 10 first, then 15, 20...and then 22. If you have an aftermarket head you're working on and need a stock head torque sequence, I'll get you a pic. bascially, Criss cross the middle 4 studs, then star pattern and work your way out. yea, no prob Bob. Thanks for the werd! :thumbsup: Quote
