Woolfman Posted March 26, 2009 Report Posted March 26, 2009 Alright I just wanted a good starting point. I just switched my stock 95 carbs for some 06 was running fine now like crap. I am currently running 310 main and stock pilot on mild dune port, t5's, cool head 20cc domes, airbox with the single k@n. I am at elevation of 4,393 ft. I was thinking maybe was running rich but old carb was gummed up enough to lean mixture I don't know. The new carbs are in great shape guy never used them but maybe once or twice. I don't know if this could be part of the problem but I have noticed that when I turn off my key it keeps running have to hit the kill switch to stop. I'll be a little more specific on runs like crap. It is a bitch to start hesitates when I hit the throttle but from then on goes like a raped ape. Suggestions please. Quote
elwilliams13 Posted March 26, 2009 Report Posted March 26, 2009 Sounds like you are lean. Go over your idle circuit and check the needle. Or you may have an airleak around the intake. Quote
Woolfman Posted March 26, 2009 Author Report Posted March 26, 2009 how much difference would it be if the airbox was off? Quote
