Fireroad Express Posted May 15, 2009 Report Posted May 15, 2009 i,m going to give you an example...my last drag bike was a 10mill dm.i had 20x10x10 on 10x9 rims sd23 and she hooked like a bitch.the reason i went with that size is cause there pretty wide at the tree for traction but they get taller as you go down the track,helping get down the track faster.gearing is also going to be a factor...i think that anything bigger for you bike will be a waste of $.we will be trying a set of ar 18x10x10 here pretty soon and i will post up results.this guy has about the same mods as you.. what were you running for gearing? Quote
dusty_v141 Posted August 10, 2009 Report Posted August 10, 2009 what are you guys running on the front? i want the real skinny one. thanks Quote
MikeB Posted August 11, 2009 Report Posted August 11, 2009 you can get jr. dragster front tires or some 10x2 spindle mounts .. check out www.wickedatv.com he has a whole bunch or eastcoastatv.com Quote
