Did you just make these mods , or are you just tuning a setup that was already
running ?
Going from TORS to no TORS will not have an effect on your jetting.
Unless you are changing the pipes or air filters you can just look and
see what mains and pilots are in the current carbs and match them.
Do a plug chop after the change to verify that the jetting is correct.
Should work if theyre the same stock carbs just without TORS
