Whats up everyone. Quick Question. I'm changing the clutch plates for a friend right now and noticed the outside of the basket is all scratched up. Anyone ever noticed this before? Should I be concerned? Any help is appreciated.
I have seen many like that,as long as the fingers that the plates ride on is not grooved restricting plate movement should be good,more times than not if it looks questionable it is
  • 3 weeks later...
quick question im new to this site and thought yall had alot of good info... i have a 99 banshee i replaced the clutch like a month ago and noticed that the clutch basket on the fingers were grooved bad. so i bought a new basket and clutch and now the clutch is slipping bad now i was going to replace the cluth again and the fingers have the same grooves.also on the back of the basket theres a gear thats really loose and not tight like it was a month ago....if anyone could help i would appreciate it...thank
If your going through a clutch a month you have big problems. Give me a call and i will fix you up with what you need.
did you replace the basket with a stock one or aftermarket? it sounds like either the cushions are worn or the screws weren't tightened properly (aftermarket basket). what kind of shape were the inner hub and pressure plate in?
everything was good when we installed the new basket (stock). im thinking we didnt tighten the center bolt right. what is the proper way to set the center screw and the locking nut. and also are there torque specs for any of the clutch parts
is the basket grooved so bad that there is no clutch movement? i've seen this done before and it works to a certain extent. take a file and file down the grooves so there is a flat surface on the fingers on the basket. never done it but have seen it work..beats buying a whole new basket right away.
i have done the file trick on some of my machines in the past. Never had any major problems with any of them since. maybe a bandaid but worked for me.
good luck
good luck
ill try that. I have have 3 banshees (1 06) (1 03) (1 99) the 03 is a drag banshee i fryied the piston 2 weeks after i bought it so i tore the whole motor apart and put all new parts i need to know the right way to adjust the clutch and the center bolt.
