travis6767 Posted March 18, 2009 Report Posted March 18, 2009 Is there a way to get the ball and rod out when welded together without spliting th case open? Quote
boneyardbanshee. Posted March 18, 2009 Report Posted March 18, 2009 you could try to tip the motor or use some kind of a stick magnet. If you have to split the cases you can do it upside down so you will not have to mess with your top end. Quote
