Chris-in-Cali Posted March 10, 2009 Report Posted March 10, 2009 Is it possible to get a decent reading on a rich/lean mixture just by putting in new plugs and letting the bike idle for a minute...maybe open up the throttle a few times in neutral...pull the plugs and check? The reason why I ask is because the closest place for me to get wide open on the throttle is at least an hour away. I would rather go out running rich and lean down from there then go out and open up that bitch running lean. Quote
DallasGDub Posted March 10, 2009 Report Posted March 10, 2009 I would ball park it and get it close to someone that has your mods and elev. Then do the fine tunning and chop. Here is a good thread: http://www.bansheehq.com/forums/index.php?showtopic=99361 Quote
Chris-in-Cali Posted March 11, 2009 Author Report Posted March 11, 2009 I would ball park it and get it close to someone that has your mods and elev. Then do the fine tunning and chop. Here is a good thread: http://www.bansheehq.com/forums/index.php?showtopic=99361 Looked thru all of it, but no one really runs pj's. or really has a similar set up. I have a drag port, cool head with 20 cc domes,v force 3's, +4 timing, and some cpi inframes. The carbs are 34mm pj's with 172 mains and cel needles on the 4rth clip. Screws turned 1.5 out. Oh yeah....I do all of my riding out in superstition,glamis or gordon's well...I think that is sea level or 1 to 2 hundred feet above. The reason why I ask is the throttle is crisp as fuck and scary responsive...which has me thinking I'm on the lean side and next thing you know....... KABOOM!!!!!!! Sound lean to you? ANYBODY????? Quote
TexasBansheeMan Posted March 12, 2009 Report Posted March 12, 2009 Turn the air screw back in a little if your worried you might be a tad lean. But you sound damn close. we tested WOT in a shed when we built my last shee. tie the ass end up in the air from the grab bar. Start that bitch put it in 6th and hammer it. DONT STAND INFRONT OF IT!! Make DAMN sure its secure and you should be fine. Quote
Rodneya Posted March 12, 2009 Report Posted March 12, 2009 You need a load on the motor when testing WOT. Lifting the back end wont really do it. Letting the motor idle will only give a reading on the pilot jet, and you can check your pilot size with the airscrew. Jet your mains close, maybe what you think is a little rich, and take spare jets with you next time you go riding. It does not take long to do some WOT runs and adjust jetting at your riding spot. Quote
