bansheefreak89 Posted March 9, 2009 Report Posted March 9, 2009 hey guys went down to badlands and had trouble getting my carbs jetted right was cutting out lowend and the very top of every gear not sure what i should be running. the thing was running good the night before i ended up with 60 pilots and 180 mains then when i got there it was not running very good. my mod list trail port trinity pipes +4 timing vforce reeds 20cc domes 28 pwk with pods 100 octane gas Quote
elwilliams13 Posted March 9, 2009 Report Posted March 9, 2009 I ran your same setup but with midrange pipes and I had a 50 pilot and 162 main. The needle is key in these carbs do a search to find out what is best I can't remember what I had off the top of my head. There is like a gazillion needle options with diffrent tapers alot of fine tuning possibilities there. Quote
Dick Wheels Posted March 9, 2009 Report Posted March 9, 2009 Start with a 165 main, 48 pilot and go from there! Also I would run a N68A or JJH needle. Start with the middle clip Quote
bansheefreak89 Posted March 10, 2009 Author Report Posted March 10, 2009 ok went with 162 mains 52 pilots and moved the needle clip to the fourth one its runs better down low is not cutting out but doesnt feel as fast top end?? Quote
dave5.0 Posted March 10, 2009 Report Posted March 10, 2009 Did you come down one size at a time from 180? I always get it to the point of puking on itself and then back it down one size at a time until it cleans out. then run it and check the plug. I did the same thing at the Badlands and it ended up running pretty good. I think I'm running a 55 pilot on my 4 mill. Where is your air screw set at? Quote
grizzly700 Posted March 10, 2009 Report Posted March 10, 2009 on my 28s i have a 48pilot and 152mains with my needle up one notch right now but i dont have a port... wat do ur plugs look like? i would move the needle and see wat happens if its worse go the other way. Quote
bansheefreak89 Posted March 11, 2009 Author Report Posted March 11, 2009 fourth notch on the clip i will ridse it some more if it ever stops raining and no i just went from 180 to 162 i will run it a bit and see Quote
bansheefreak89 Posted March 11, 2009 Author Report Posted March 11, 2009 i have not touched the air screw at all and i dont know whats its set at. i am new to the jetting thing just bought these carbs from cascade?????? Quote
grizzly700 Posted March 11, 2009 Report Posted March 11, 2009 180 to 162 is a pretty big drop in jetting. i would make sure your carbs are synced first. my air screws on my 28 are about 1 3/4 turns out of seated snuggly. Jd might have the carb sync tool. you can do it by eye but its up to u. have you done a plug chop? oh yeah and ur a-arms are badass nick. Quote
bansheefreak89 Posted March 11, 2009 Author Report Posted March 11, 2009 thanks man i will check the air screw tom and as far as a plug chop where is the info to see what its suppossed to look like Quote
grizzly700 Posted March 11, 2009 Report Posted March 11, 2009 thanks man i will check the air screw tom and as far as a plug chop where is the info to see what its suppossed to look like ill find it dude. hold on i been lookin for it. go look at tits for a min in the general discussion room while ur waitin lol. Quote
grizzly700 Posted March 11, 2009 Report Posted March 11, 2009 (edited) this one u have to scroll down till u find the big pic of the plug, but its pretty informative. almost to the bottom. plug chop link #1 this one is ok by the book way i dont actually cut my plugs. i just look down in them to see wat they look like. :thumbsup: Edited March 11, 2009 by grizzly700 Quote
