hey guys went down to badlands and had trouble getting my carbs jetted right was cutting out lowend and the very top of every gear not sure what i should be running. the thing was running good the night before i ended up with 60 pilots and 180 mains then when i got there it was not running very good.
my mod list
trail port
trinity pipes
+4 timing
vforce reeds
20cc domes
28 pwk with pods
100 octane gas
I ran your same setup but with midrange pipes and I had a 50 pilot and 162 main. The needle is key in these carbs do a search to find out what is best I can't remember what I had off the top of my head. There is like a gazillion needle options with diffrent tapers alot of fine tuning possibilities there.
Did you come down one size at a time from 180? I always get it to the point of puking on itself and then back it down one size at a time until it cleans out. then run it and check the plug. I did the same thing at the Badlands and it ended up running pretty good. I think I'm running a 55 pilot on my 4 mill. Where is your air screw set at?
on my 28s i have a 48pilot and 152mains with my needle up one notch right now but i dont have a port... wat do ur plugs look like? i would move the needle and see wat happens if its worse go the other way.
180 to 162 is a pretty big drop in jetting. i would make sure your carbs are synced first. my air screws on my 28 are about 1 3/4 turns out of seated snuggly. Jd might have the carb sync tool. you can do it by eye but its up to u. have you done a plug chop?
oh yeah and ur a-arms are badass nick.
thanks man i will check the air screw tom and as far as a plug chop where is the info to see what its suppossed to look like
ill find it dude. hold on i been lookin for it. go look at tits for a min in the general discussion room while ur waitin lol.
this one u have to scroll down till u find the big pic of the plug, but its pretty informative. almost to the bottom.
plug chop link #1
this one is ok
by the book way
i dont actually cut my plugs. i just look down in them to see wat they look like.
:thumbsup:
Edited by grizzly700
