HEY GUYS!!!! I NEED SOME ADVICES ON WHAT JETS TO PUT IN MY BANSHEE!!! I GOT MAIN 190 IN IT RIGHT NOW!!!! BUT IT SEEMS TO BE RUNNING REALLY RICH AND IT HAS REALLY BAD THROTTLE CONTROL!!! ( IT TAKES IT 5 SEC TO HIT THE POWER BAND LOL)!!!!!! I WOULD LIKE TO HAVE SOME JETS TO WILL MAKE IT RUN REALLY GOOD AND IT WILL HAVE ALOT OF THROTTLE CONTROL!!!!! PLEASE HELP AS I HAVE A RACE WITH IT TOMMOROW, SO I HAVE TO REJET IT TODAY I have original reeds, fmf pipes, Knn air filter, original carbs, jetting would be for summer... weather around 17-23, my elevation is approximately 1048 m (3440 ft) above sea level
if you run summer jetting for the race, you could melt a piston. if you are running the gas from the local station up there, i'd say you'll be closer to the 300-320 range, and have to play with the needle to get the midrange right
