Im at 280 and 27.5 32:1 mix t-5 pipes and K&n Filter With big holes in the lid. Alt is 846, needle is 2nd from top. Shee is kind of hard to start unless I tilt bike to side to flood carbs then starts on second kick. But it also has a dead spot at qt throttle. Im putting vforce reeds on tomm. Can you help me diag. my dead spot is bugging me. Think Im lean but not quite sure. Thanx in advance
Try third position and go down to a 270 main. The dead spot is the needle has it slightly leaned out but ironically you might be too rich on top with a 280 in it. Try the needle first on third position and if it is too rich you need to move down one jet size and needle in the middle spot.
