cjtl1000r Posted March 2, 2009 Report Posted March 2, 2009 I just bought a 97 shee that was locked up. After getting the head and jugs off I checked the bore and found they are about .075 over stock. I Quote
magz Posted March 2, 2009 Report Posted March 2, 2009 (edited) I just bought a 97 shee that was locked up. After getting the head and jugs off I checked the bore and found they are about .075 over stock. I'm already looking at replacing the crank due to a seized rod bearing so should I bore the cylinders out more or try to find a good stock set? I'm not sure how much more they can be bored and still use a stock crank. I'm not looking for a lot of power gain just dependability. Any suggestion? i thought 100 over was max i believe, someone should chime in to confirm im sure. what are your plans in the future? plan on doing any mods like port work? id probably find a set of stock, unknifed heads.. heres where i recieved my answer looking it up on the search button http://www.bansheehq.com/forums/index.php?...4&hl=boring Edited March 2, 2009 by magz Quote
cjtl1000r Posted March 2, 2009 Author Report Posted March 2, 2009 One guy told me they were probably toward the end of there life but would probably make one more boring. As for future plans I would really just to keep it as stock as I can. Most of my riding will be trails and lots of speed won't be need. I just want something to play around on. Quote
AWR Posted March 2, 2009 Report Posted March 2, 2009 (edited) you can get .080-.090-.100 over pistons.any decent machinist can tell you which ones you need.i have seen some cylinders that would not go .100 over(to thin)if you have an after market head you have to use big bore domes on the .090 and.100.i ran a .100 over engine for a couple of years it was the best one i ever had.ihung the on cylinders on the wall..TEARS... Edited March 2, 2009 by AWR Quote
