  • Replies 38
  • Created
  • Last Reply
Top Posters In This Topic
It's hard to think that Michigan's economy is one of the worse, however it seems we have the most guys stepping up to some big motors this year, and they sure as hell are not cheap. Did I miss a handout somewhere. :shrug:
Damn, I should have known something was going on. I knew I shouldn't have signed up for that damn night class :banghead:
421 cub cleanup port on alky with 30 shot of nos
I was about to ask what times you run, until I read your sig. Not sure about that gearing, but I don't usually run wedges. Couldn't you run a 14/44 and get a little more torque out of it, with the same ratio? I run 15/43 on my 421, with 78 r/o paddles though. Those wedges like to grow unless you have them on 10 inch wide wheels.
No doubt you should see some 3.9s on that once you get it dialed in :thumbsup:
yea thats a typo i need to fix ,,,its a 14 41 and yea i ran a 14 44 on the stock stroke cub and was geared right on for stretching 4th at the line so i figure with the +10 or so hp and the bigger heavier prowedge 1's on 10's it should be in the pullin rpm range in 4th with the 14 41 ..but with the nos it should just blow the tires off ,,,im thinking about running a 15 with juice..
did you launch in 2nd with the 15 43 abd how far over was ya????
im also 200lbs that make a diference....
the track i run is harder dirt ,,,only paddles that run are the terrain traks with the H paddles on them...
its a real fast track though,,,i mean for slower bikes it s freaky fast but us bigger guys have trouble making it hook on the big end...
i would say if i hook i should run around a 3.92 off the bottle....but take for example a bone stock can am rennagade will run a 4.90 on a good night.....
ive seen bone stock banshee's strutted with prowedge 2's run 4.90's as well....but after the sunsets the dew falls us faster guys just give it up...lol
matt
