I just purchased a 2002 Banshee today :biggrin: ! I have a couple of questions:
-What is done when you remove the TORS (I'm pretty sure mine is already removed, but I want to make sure its right)?
-I want to remove the twist throttle and install a thumb throttle...what parts do I need?
Thanks.
If you don't have this big hunk of metal on top of your carb caps then your TORS are gone. If you want to get rid of your twist throttle you can trade me for my thumb throttle. If your twist throttle isn't to beat up. We would just need to trade the throttles and cables as long as your tors are already gone. If not then you would need new caps.
I can send you pics of my twist throttle if you are interested. Could you get me the thumb throttle by Friday? We are riding next weekend. I live in Maysville, KY 41056. Thanks.
Here is my twist throttle...let me know what you think (its made by ITC and works good):
Are my TORS deleted?
Are these plugs for the TORS?
Could my idle problem be realted to the TORS? Thanks.
Edited by dbdragracing
Ok do you still want to trade?
Yes your TORS are gone and those do look like the plugs for the TORS. I think your idling problem is from not installing an idle screw kit but I would need pics of the sides of your carbs to see if they did install them..
Oh and some heads up if you want to trade. Don't send the caps our cables should work on either cap. Also just so you know you will need new grips if you didn't already know.
