clutch side... thats the side they slide out ...
The e-clips go on the stator side. Keep them from punching through the case. The shift cam retainer holds the front one from coming out of the clutch side, and there's a tab behind the shift spring rod that holds the other one in. You can see what I'm talking about right here.
i thought he was talking bout the rod the shift forks ride on.. i was trying to remember when i did mine thought it was clutch side.. guess i might be wrong.. either way thou the rod itself only has one groove for the clip..
I think he is talking about the rods that the forks slide on. Thats what I was shoeing in that pic. You can see them sticking out the side of the bottom case. One on both sides of the shift star. That's what I was trying to point out. They're held in by those retainers, on the clutch side.
the notches on the shafts where the e-clips fit on are on the stator side of the engine. as the pictures show the opposite end of the shafts are held in by washer on the shift shaft adjuster and the shift drum retainer plate....
