Just broke a piston on my '99 banshee...its been ported with the stock crank. So i can get a welded 4mil crank cheap from a guy i know, but ive read that after you port it with the stock crank, you cant goto the 4mil. how true is this? and if i put the 4mil in, is there just some small porting i can do to make it work right?
thats all i have to do is put the plate in? and everything will line up right?
I would call an engine builder and get your jugs checked out. sometimes you can still have them ported again to match a 4mill depending on what kind of port job you got the first time. I would try not to use a spacer plate. if they can port your jugs for the 4mill i would get that done and have the stock head cut for the stroker or get a noss head with cut domes.
yeah i would do this myself.. but to run them as they are ..i was just stating you would have to run a plate... so it your chioce.
