does ocatane boost make your bike run hotter then just ur regular mixed gas? also what is the normal operating temperature for a banshee in kansas? one more thing, is there a way of making a homemade temp gauge for the bike, the good ones are sooo dang expensive! help me out fellas..
thanks..
if your bike requires a higher octane fuel, i wouldn't use octane boost. they make race fuel for a reason. adding too much octane boost will make your engine work like a POS. i tried it in an old bike i had when i was a kid,not knowing any better. and as i remember the bike did over heat, cause the oct.boost leaned out the fuel/air ratio. octane boost = form over function!
Don't use the octane boost i put some in my bike last summer, the klotz, didn't even put much in it ran and smelled good but a couple rides later i was doing a top end rebuild :down:
well my motor is freshly broken in, i checked my compression and it was like 170psi on both cylinders, jeff at FAST told me to run a little octane boost in my gas just to boost up the octane a bit, i dont think that the octane boost did that to your top end cause i dont think he would have me do that if it would do that to your engine...
