robert0762 Posted February 22, 2009 Report Posted February 22, 2009 I just got my banshee running. I bought it not running so I don't know how it ran before. It is stock except being bored out .080 over. My prob is I can't get it to idle and my plugs are giving me a rich reading up to 1/4 throttle. This is weird cause I tried to adjust air screw I took it 2.5 turns out and still get a rich plug also I had the air box open and no filter and still got a rich plug but I have to choke it to get it start to even if its warm. It was booging really bad from a low rpm but turning the air up helped that so now it just kind of hesitates a lil right before powerband if its not already revved up. So could it be reeds or is it def a jetting issue. I personally have never had to change out pilot jets and I'm geussing they r stock like everything else on the bike Quote
vulvafan537240 Posted February 23, 2009 Report Posted February 23, 2009 what mods? stock pilots are probably too small if you have pipes and pods . Quote
robert0762 Posted February 23, 2009 Author Report Posted February 23, 2009 stock everything but the silencers r missing the insertsand its 80 over Quote
robert0762 Posted February 23, 2009 Author Report Posted February 23, 2009 any iodeas guys??????????? Quote
gorethrasher Posted February 25, 2009 Report Posted February 25, 2009 Turn pilot screw IN to lean off. I found my bike is hard to start if pilot is wrong. Quote
blaster2006 Posted February 25, 2009 Report Posted February 25, 2009 Turn pilot screw IN to lean off. I found my bike is hard to start if pilot is wrong. wth? no? if you tighten the air screw it gets richer. loosen it gets leaner. Quote
gorethrasher Posted February 26, 2009 Report Posted February 26, 2009 wth? no? if you tighten the air screw it gets richer. loosen it gets leaner. oops, I guess I had it wrong. Quote
