why whats wrong with it?
i can't remember if it has to do with the clutch, gears, or seals, but something made me cringe, as it will damage one of those. i was looking at the chevron iso oils we use at work, and we do chew through pumps, and blow ram seals. it's basically cheap, lightweight oil, with anti-foaming agents. do a google search on the specific oil you were thinking of, and you should find some data on it.
well i dont know, you got me scared now. im gonna replace my clutch before the dune season, i might just try it out i got alot of john deere hygard. its a little thicker than ATF. but if you take a look at a tractors transmission. they got wet clutches and shit like that. the only problem i could see is maybe the seals are not the same material or something. i guess if it smokes some stuff ill let you give me the i told you so speech.
