banshrider Posted February 21, 2009 Report Posted February 21, 2009 ok so i know this topic has been brought up alot but my banshee only seems to be running on the right side , ive gone over the bike lookin at the stuff ive seen in other threads , comps good, brand new pistons rings and bored, swapped the wires , new plugs , cleaned the carbs like 6 times , flushed the fule tank and cleaned the filter, adjusted the stator, checked for vacume leaks and replaced the carb boots , but still it sputters and pops on the left side just wondering i went to adjust the idol screw and it seems that it broke inside the toro on the left side and the threadded piece is still stuck in it , could this be causeing my problem only other things i can think of is mabe the reeds or the crank seal what do you guys think also can i just replace the idol screw i cant find just the screw on the yamaha parts website, was thinkin of just removin the toros since they cause so many problems Quote
shee4speed Posted February 21, 2009 Report Posted February 21, 2009 definately remove the TORS and be done with that POS. then you can go from there. Quote
