jlsparky7 Posted February 19, 2009 Report Posted February 19, 2009 2004 banshee completely stock engine and pipes. Only power mod is a K&N air filter with modded air box. Bike wont start at all unless I flip it up on the grab bar with the gas on then flip it back down. It runs great after I get it started. To me that sounds like it would have to be a float problem. How do I adjust the floats? Quote
AKheathen Posted February 19, 2009 Report Posted February 19, 2009 how did you come up with that one? your sig says ptr mids. have you re-jetted and adjusted your airscrews? clean your carbs out good, and hold them upside down with the bowls off. the top of the float in this orientation should be 21-22mm from gasket surface, without the gasket on. you adjust by bending the tab that the needle clips to Quote
jlsparky7 Posted February 23, 2009 Author Report Posted February 23, 2009 (edited) how did you come up with that one? your sig says ptr mids. have you re-jetted and adjusted your airscrews? clean your carbs out good, and hold them upside down with the bowls off. the top of the float in this orientation should be 21-22mm from gasket surface, without the gasket on. you adjust by bending the tab that the needle clips to I had PTR mids but they ended up being the j-arm type and I had to sell them cause they wouldnt fit. I havnt managed to find a good set since then. That was the exact answer I was looking for to adjust the floats! thanks a lot man! The way i figured it out was everytime I unloaded it right out of my truck and tried to start it, it fired up no problem. If it was sitting in the garage for a bit and I try to start it, it wouldnt start. Edited February 23, 2009 by jlsparky7 Quote
