mignumspeed Posted February 18, 2009 Report Posted February 18, 2009 mine is leaking oil do i have to take the case apart to change it? Quote
THE GRIM RIPPER Posted February 18, 2009 Report Posted February 18, 2009 No, take the stator cover off.... shifter off..... Pop the seal out with a pick tool, grease the new one up and slide it in. And change the oil Quote
rubberneck Posted February 18, 2009 Report Posted February 18, 2009 Not hard to do the seal, however if your shift shaft is badly grooved, it may only be a bandaid or temp at best. My brothers bike leaked when i got it put a seal in but it only slowed it down. pulled the clutch cover and put in new shift shaft and seal and life was good. Quote
mignumspeed Posted February 19, 2009 Author Report Posted February 19, 2009 Not hard to do the seal, however if your shift shaft is badly grooved, it may only be a bandaid or temp at best. My brothers bike leaked when i got it put a seal in but it only slowed it down. pulled the clutch cover and put in new shift shaft and seal and life was good. thanks i'll look at mine and try it. Quote
