Nick_R_23 Posted February 15, 2009 Report Posted February 15, 2009 On the banshee Im rebuilding, I think someone already did the TORS removal. None of the electrical parts are there, throttle is siliconed, and carbs have none of that extra crap on them. The stuff thats on the carbs now (caps, throttle cable) look like the Vito's TORS removal kit. The problem is, the throttle cable is missing some part in the middle and the idle screws are confusing me. I read that the carbs must be drilled and tapped for the idle screws and I think somebody may have screwed up. One of the carbs has the idle screw, and the thread size is M6x0.75. The other carb is missing its idle screw, but the threads where it would go are M8x1.0, which is obviously a lot larger. Did someone mess this up?? What do I do now? -Nick Quote
BlasterKX Posted February 15, 2009 Report Posted February 15, 2009 ya it sounds like someone may have broken the tap off in the one carb and got it out and just put a bigger hole and couldnt find a idle screw maybe?? those taps r a pain in the ass Quote
