I just put together a 4mm stroker with 66mm pistons. Complete rebuild. I am running stock carbs. My issue is at idle I have more pressure coming out of the clutch side pipe compared to the flywheel side pipe (CPI inframe SB). Once the bike gets going they both have even pressure and the bike rips. I also did a compression check and both cylinders are dead even. I know the crank seals are good, so I am thinking maybe a sticky choke or carb sync? Any help would be great.
