DGFUNNY70 Posted February 10, 2009 Report Posted February 10, 2009 I know I am probably over thinking this but how much difference do you think there is between these two tires. I'm thinking by the time you squeeze a 12-inch wide tire on an 8-inch rim it will be about the same height. Also if you are running the standard Douglas wheel what wheel thickness are you running? Quote
BumpaD_Z28 Posted February 10, 2009 Report Posted February 10, 2009 Well I am currently running 21x12x8 10 Paddles , and although they work pretty well, I think my next set is going to be 22x11x8 9 Paddles ... You are right it thinking that the 12" wide on a 8" wide wheel crowns the top of the tire, and I don't really like that effect, I think the paddles might be more "efficient" if left at a more horizontal profile ... Maybe that helps ... ~DaVe Quote
FireHead Posted February 11, 2009 Report Posted February 11, 2009 The larger diameter floats better. I only recomend 22" or larger tires for duning. Quote
BigRed350x Posted February 11, 2009 Report Posted February 11, 2009 The larger diameter floats better. I only recomend 22" or larger tires for duning. Is this recommendation pre-box-o-wine or post? I'd go with the 22" tire as well. Quote
FireHead Posted February 11, 2009 Report Posted February 11, 2009 Is this recommendation pre-box-o-wine or post? I'd go with the 22" tire as well. Pre........... I am a bit of spaz this evening. :biggrin: Quote
BUILDER Posted February 12, 2009 Report Posted February 12, 2009 I know I am probably over thinking this but how much difference do you think there is between these two tires. I'm thinking by the time you squeeze a 12-inch wide tire on an 8-inch rim it will be about the same height. Also if you are running the standard Douglas wheel what wheel thickness are you running? I run the 21x12x8 ten paddles on mine and i love them. I have ran the 22 and i much prefer the 21 but thats just me. Quote
