Chris-in-Cali Posted February 9, 2009 Report Posted February 9, 2009 Any tricks of the trade I should know before pulling the stock and installing the new? Quote
Hilarious Posted February 9, 2009 Report Posted February 9, 2009 Any tricks of the trade I should know before pulling the stock and installing the new? be aware of the little ball (the piece between the pushrod and adjuster) if it should happen to fall out onto your shop floor or where ever you are working. it can be very frustrating to put everything back together and you see it lying underneath the bike. :thumbsup: Quote
dajogejr Posted February 9, 2009 Report Posted February 9, 2009 That...or when it falls DIRECTLY into your oil/antifreeze drain pan. That's my personal favorite...drove around all day one time to try and match it up, thought I lost it. Couldn't find it. Then got home and moved my drain pan and heard "something" rolling around inside. Oh boy....LOL. Leave the cable disconnected from the perch OR the arm on the disengagement lever...you only need to apply pressure from your hand to adjust it properly.... Quote
Chris-in-Cali Posted February 9, 2009 Author Report Posted February 9, 2009 (edited) thanks bros...got the feeling, you just saved me from a major headache! Edited February 9, 2009 by my-dixie-wrecked Quote
Justintoxicated Posted February 10, 2009 Report Posted February 10, 2009 (edited) thanks bros...got the feeling, you just saved me from a major headache! Depending on the version you have the install process may vary. On the version I have I remember having to put the clutch pressure plate together, then adjust the pancake, then take the clutch pressure plate (attached by the screws with springs over them) back off so I could grab onto it from the backside to sinch it tight and lock the adjustment in place. The first time I was not able to tighten it enough and it spun off into my clutch case and trashed my lockup clutch (actualy it still would probablty work fine but I decided to replaceit anyways. $100 mistake (luckily that is all)... Edited February 10, 2009 by Justintoxicated Quote
TNTS355 Posted February 10, 2009 Report Posted February 10, 2009 I oredered a longer screw, the one it comes with is not long enough for me. There was only about 3 threads showing when I had it adjusted correctly. Someone on BHQ put a thread up on it. Ordered mine through Fastenal. Quote
Chris-in-Cali Posted February 10, 2009 Author Report Posted February 10, 2009 Depending on the version you have the install process may vary. On the version I have I remember having to put the clutch pressure plate together, then adjust the pancake, then take the clutch pressure plate (attached by the screws with springs over them) back off so I could grab onto it from the backside to sinch it tight and lock the adjustment in place. The first time I was not able to tighten it enough and it spun off into my clutch case and trashed my lockup clutch (actualy it still would probablty work fine but I decided to replaceit anyways. $100 mistake (luckily that is all)... Fuck!!....sounds like a major pain in the ass :: Got it from cascade....so.. wish me luck! :beer: Quote
Snopczynski Posted February 10, 2009 Report Posted February 10, 2009 When you put the clutch hub on, make sure its sitting flat on the clutch packs. If there is a gap, take it off and rotate one hole to make it flat. Quote
Chris-in-Cali Posted February 10, 2009 Author Report Posted February 10, 2009 When you put the clutch hub on, make sure its sitting flat on the clutch packs. If there is a gap, take it off and rotate one hole to make it flat. sounds right!! thanks bro!! Quote
