ok so y would i run 3stock 3hd when its still sliping is there a better tranny fluind to try i have sea 10w30 now ..... thanxs 4 the ass comments :biggrin:
Do you have porting done to your cylinders?
If not...and it's slipping, there's a few reasons it could be:
worn clutch
misadjusted clutch
Not changing fluid often enough (80W Gear saver oil is just fine)
Worn clutch components (inner hub, pressure plate and/or basket)
Garbage cheap clutch
Edited by dajogejr
ok i asure u the clutch plates r brand new and there is about a 1/4 inch wiggle in the lever and the hd springs are brand new so i will try the 80w oil and see what happens idk what kind of plates they r but if the oil doesnt work i will try new plates then maybe a new basket/pressure plate .... it only slips like into 5th and sixth other than that its ok
went ahead and got a pancake bearing from cascade....should have went someplace else...I ended up spending like 300 bucks on a bunch of other stuff while I was there. That is one kick ass website they got going on over there :evil:
Anyhow...When installing the pancake bearing is there anything I should know?
or is it pretty cut and dry just unscrew the stock and install the new?
Thanx for any replies!!
Edited by my-dixie-wrecked
