mignumspeed Posted February 4, 2009 Report Posted February 4, 2009 i bought a twist throttle and idle kit and it didnt come with instructions on where to drill and tap the carbs anyone help? Quote
AKheathen Posted February 5, 2009 Report Posted February 5, 2009 i bought a twist throttle and idle kit and it didnt come with instructions on where to drill and tap the carbs anyone help? there is a nipple just under where the cap retainer scrwes in. you have to shorten it about 3/8" for the jam nut to fit, or it won't idle high enough. if you look ath the 45 degree recess at the bottom of the side of the slide when you take it out, you'll see where it needs to be. Quote
mignumspeed Posted February 5, 2009 Author Report Posted February 5, 2009 there is a nipple just under where the cap retainer scrwes in. you have to shorten it about 3/8" for the jam nut to fit, or it won't idle high enough. if you look ath the 45 degree recess at the bottom of the side of the slide when you take it out, you'll see where it needs to be. thanks i see what your talking about ive got them drilled and tapped and i took some off the nipple,it looks good Quote
RUDEDAWG Posted February 5, 2009 Report Posted February 5, 2009 thanks i see what your talking about ive got them drilled and tapped and i took some off the nipple,it looks good Just be sure you de-burr where the idle screw pokes into the inside of the carb so that the slide doesnt get stuck. :thumbsup: Quote
