Emmerrrrr Posted February 2, 2009 Report Posted February 2, 2009 I was thinking about going with the +4 mil crank. Will this change what kind of pistons i order what all is needed to make this kit i was reading a little bit on it ... Quote
vulvafan537240 Posted February 2, 2009 Report Posted February 2, 2009 if you get the long rod 4mill, you will need wiseco 795 pistons. if you get a std rod 4mill, you can use std pistons. you will need to get the jugs ported and stroker domes or mill the head if its a stock head. Quote
