sorry Joe...
For some reason I thought you were going cub with bigger carbs...didn't realize you were running OEM cylinders and 35PWKs.
You can grind down the float bowl drain screw, you can bend the clutch arm down ( you can do a combo of these two) or you can buy the intakes with the crossover built in to space it away...
