pry a stupid question bot when i put oil in my banshee it leaks out under the water pump ?????? i put the outer cover on and it leaks out the bottom should there be a gasket or should i use rtv or why is it leakn???? thanks guys
there is a vent hose that goes back there. It is probaby poped off or not there.
thank you do you know where i should run the vent hose out im not see n ne thing i had bought the plug that goes there but it is not what i thought so it does have the plug but no vent hose???
some put a rubber plug over that vent.
there is a small hole in the clutch cover over the water pump to route
the vent line up to the frame underneath the gas tank.
