Got a little more information...I live in phoenix and ride at Glamis so I'm between sea level and 500 ft. and temp. is 60-70 degrees. I'm currently running 158 mains, 48 pilot and the needle is a CEL set on the middle clip which was dialed in pretty close for the T6 pipes I was using. When I switch to the CPI's can I use the same setting or should I adjust and if so, what? My other mods are in my sig...
I bet your pretty close right now.
I'm running the same engine setup with shearer pipes and eek needle at Glamis.
158mains
48pilots
EEK needles middle clip
Running strong with 1.5 yrs still on the same topend.
I think I figured it out...I went up 10 sizes on the mains which blows my mind and clearly illustrates the true difference in potential between drag pipes and regular pipes like Toomeys on a modded motor!
My main is now a 168 and my pilot is a 55 with a cel needle. I'm thinking though that tomorrow I will try a 52 pilot because right off idle I'm getting a slight hesitation or bog... I will post my results as soon as I get them.
