i took my carbs off tonight and my slides are very black is this comen and should i clean it befor i reassamble the bike and if this isnt comen then how can i fix it and thanks alot to everyone on here helping me figure out my bike a little better
Ive seen many black slides in stock carbs......its common..
i believe it's a friction coating from the factory
I agree.
If you have an older bike, your slides might wear out a bit, you can see it changing back to silver, and they'll start to "hang up" on you, and not slide as smoothly.
Or if you nick a slide by forcing it in the wrong way, and it gets a small burr in it...then you can sand it off.
My slides were partially black when I bought my 03 banshee used. It was just old oil and dirt and washed off with a bit of gas. She ran much better after cleaning cause the slides moved freely with no sticking
thats kinda what i thought man thanks alot ill clean them up tomorrow night thanks for the help
someone probably removed the coating before you got it it's a coating from the factory, but i'm just not sure if it's friction coating or not. should be covered all the way around and look like black paint. i wouldn't scuff it off, but do what you want. :shrug:
Don,t think so. The slides are the same gold color all over, even in the groove and top and bottom
maybey it changed over the years. mines a 97. i could be wrong :shrug:
does anyone else know for sure? :ermm:
