gsxr to banshee Posted January 28, 2009 Report Posted January 28, 2009 I have a 03 Banshee and i am not getting spark to the left plug if you are sitting on the machine. what is wrong and how can i test Quote
bansheefreak Posted January 28, 2009 Report Posted January 28, 2009 welcome to the site... so you get spark when not sitting on the machine??? i would check for broken or fried wires around the seat.. and or switch plugs see if problem follows the plug wire..if so get new ones... Quote
gsxr to banshee Posted January 28, 2009 Author Report Posted January 28, 2009 welcome to the site... so you get spark when not sitting on the machine??? i would check for broken or fried wires around the seat.. and or switch plugs see if problem follows the plug wire..if so get new ones... it starts but only has spark to right plug and not sure if that has to do with coil box or what Quote
AKheathen Posted January 28, 2009 Report Posted January 28, 2009 it starts but only has spark to right plug and not sure if that has to do with coil box or what either the cap or wire to that plug Quote
vulvafan537240 Posted January 28, 2009 Report Posted January 28, 2009 swap plug wires and see if the problem moves to the other cyl. Quote
gsxr to banshee Posted January 28, 2009 Author Report Posted January 28, 2009 swap plug wires and see if the problem moves to the other cyl. i tried moving the wires to other side still ony fired up on right side left side still dead,then checked gap in plugs .028 ins on both. I also checke compres on left side and it was at 100.00 any ideas Quote
AKheathen Posted January 28, 2009 Report Posted January 28, 2009 i tried moving the wires to other side still ony fired up on right side left side still dead,then checked gap in plugs .028 ins on both. I also checke compres on left side and it was at 100.00 any ideas you put new plugs in right? 100 is low, hold the throttle open, and kick it like 15 times, untill the needle stops going up. check both cylinders. what's your altitude? Quote
gsxr to banshee Posted January 28, 2009 Author Report Posted January 28, 2009 You know what _uck it i will just tear the whole quad apart and re do it all thank you for your help guys i really apriciate it. i will just turn it into a sick banshee Quote
